Name* Member #*
Email*
Phone*
Best Time to Reach You*
Please select the course...* Choose one Welding Sales Representative Fabrication Math I Fabrication Math II Metallurgy I Metallurgy II Destructive Testing Nondestructive Testing Economics of Welding Safety in Welding D17.1 Code Clinic D1.1 Code Clinic API 1104 Code Clinic Understanding Welding Symbols Welding Fundamentals I Welding Fundamentals II Welding Fundamentals III WPS/PQR Explained
Welding Sales Representative Select Module Module 1 Standard Welding Terms and Definitions Module 2 Safety in Welding, Cutting, and Related Processes Module 3 Shielding Gas Application Module 4 Electrical Requirements of Welding Power Supplies Module 5 Shielded Metal Arc Welding Module 6 Gas Tungsten Arc Welding Module 7 Gas Metal Arc Welding Module 8 Flux Cored Arc Welding Module 9 Submerged Arc Welding Module 10 Welding Procedures & Procedure Qualification Records Module 11 Cutting Processes Module 12 Brazing and Soldering
Fabrication Math I Select Module Module 1 Introduction to Whole Numbers Module 2 Addition of Whole Numbers Module 3 Subtraction of Whole Numbers Module 4 Multiplication of Whole Numbers Module 5 Division of Whole numbers Module 6 Introduction to Fractions: Identifying and Simplifying Fractions Module 7 Introduction to Fractions: Mixed Numbers and Improper Fractions Module 8 Addition of Fractions: Adding Like and Unlike Denominators Module 9 Addition of Fractions: Adding Unlike Denominators and Mixed Numbers Module 10 Subtraction of Fractions and Mixed Numbers Module 11 Multiplication of Fractions and Mixed Numbers Module 12 Division of Fractions and Mixed Numbers Module 13 Introduction to Decimal Numbers Module 14 Addition of Decimal Numbers Module 15 Subtraction of Decimal Numbers Module 16 Multiplication of Decimal Numbers Module 17 Division of Decimal Numbers Module 18 Conversion of Decimal Numbers and Fractions
Fabrication Math II Select Module Module 1 Introduction Module 2 Percentages and Ratios Module 3 Rates and Ratios Module 4 Exponents and Scientific Notation Module 5 Order of Operations Module 6 Unit Conversions: Metric/U.S. Standard Characteristics Module 7 Unit Conversions: Temperature and Time Module 8 Lines and Angles Module 9 Rectangles and Squares Module 10 Area of Right Triangles Module 11 Area of Non-Right Triangles Module 12 Area of Circles Module 13 Three Dimensional Shapes and Volume Module 14 Three Dimensional Shapes and Volume: Cones Module 15 Three Dimensional Shapes and Volume: Cylinders
Metallurgy I Select Module Module 1 All About Atoms: The Elements Module 2 All about Atoms: The Atom Module 3 All about Atoms: Electrons Module 4 The Periodic Table: Metals, Nonmetals, and Metalloids Module 5 The Periodic Table: Periodicity and Valence Electrons Module 6 Ionic Bonds: Main Group Elements Module 7 Ionic Bonds: Transition Metals Module 8 Ionic Bonds: Reactivity of Metals Module 9 Ionic Bonds: The Structure of Crystal Lattices Module 10 Covalent Bonds Module 11 Metallic Bonds: Material Properties Module 12 Metallic Bonds: Alloys and States of Matter
Metallurgy II Select a Module Module 1 Atoms, Unit Cells, and Crystal Structures Module 2 Alloys, Diffusion, and Solid Solubility Module 3 Phase Diagrams Part I Module 4 Phase Diagrams Part II Module 5 Physical and Mechanical Properties Module 6 Thermal Characteristics: Thermal Conductivity and Density Module 7 Thermal Characteristics: Specific Heat and Diffusivity Module 8 Metallurgical Considerations for Welding Module 9 Heat Treatments Module 10 Stresses and Stress Relief Module 11 Welding Metallurgy of Common Materials
Destructive Testing Select a Module Module 1 Introduction to Destructive Testing Module 2 Strength Module 3 Ductility Module 4 Strength Testing I Module 5 Strength Testing II Module 6 Strength Testing III Module 7 Hardness Module 8 Hardness Testing Module 9 Toughness Module 10 Toughness Testing Module 11 Fatigue I Module 12 Fatigue II Module 13 Fatigue Testing Module 14 Soundness Module 15 Chemical Properties Module 16 Corrosion Testing Module 17 Metallography
Nondestructive Testing Select a Module Module 1 Introduction to Nondestructive Testing and Discontinuities Module 2 Common Discontinuities and Their Causes Module 3 The Science of Sight Module 4 How to Perform a Visual Test Module 5 The Science of Capillary Action Module 6 How Capillary Action Works in Penetrant Testing Module 7 The Science of Magnetism Module 8 How Magnetism Works in Magnetic Particle Testing Module 9 The Science of Radiation Module 10 Radiation Safety Module 11 How Radiation Works in Radiographic Testing Module 12 The Science of Sound Module 13 How Sound Works in Ultrasonic Testing
Economics of Welding Select a Module Module 1 Process Variables: Current, Amperage, Voltage Module 2 Process Variables: Polarity, Inductance, Arc Length, CTTWD, Shielding Gas Module 3 Process Variables: Travel Angle, Transverse Angle, Travel Speed, Electrode Position, Wire Feed Speed Module 4 SMAW: Process Variables Module 5 GTAW: Process Variables Module 6 GMAW: Process Variables Module 7 FCAW: Process Variables Module 8 SAW: Process Variables Module 9 Weld Process Comparison: Advantages and Disadvantages I Module 10 Weld Process Comparison: Advantages and Disadvantages II Module 11 Manufacturing Costs: Materials, Labor, Equipment, Overhead Module 12 Welding Procedure Specification Module 13 Determining the Cost of Weld: Calculating Area Module 14 Determining the Cost of Weld: Calculating Volume Module 15 Determining the Cost of the Weld: Calculating Deposited Weight Module 16 Determining the Cost of the Weld: Calculating Deposition Efficiency Module 17 Determining the Cost of the Weld: Calculating Deposition Rate Module 18 Calculating Labor Costs: Arc Time, Non-Arc Time, Total Labor Time Module 19 Calculating Labor Costs: Operator Factor Module 20 Calculating Labor Costs: Problem Solving Module 21 Calculating Filler Metal and Labor Costs: Problem Solving Module 22 Calculating Weld Job Costs: Problem Solving Module 23 Managing Costs: Joint Design, Weld Design, WPS, Mistake Proofing, Production Planning Module 24 Managing Costs: Eliminating Operations, Supporting Activities, Field Welding, process Selection Module 25 Managing Costs: Unforeseen Costs, Quality Issues, Overwelding Module 26 Practice Problems: 15 Problems Module 27 Practice Quiz 1: 5 Problems Module 28 Practice Quiz 2: 5 Problems Module 29 Practice Quiz 3: 5 Problems Module 30 Practice Quiz 4: 5 Problems
Safety in Welding Select Module Module 1 Introduction to Welding Safety: The Importance of Safety, Locating Safety Guidelines, and Safety Roles and Responsibilities Module 2 Radiation: Hazards and Prevention Module 3 Electric Shock: Hazards and Prevention Module 4 Fires and Burns: Hazards and Prevention Module 5 Fumes and Gases: Hazards and Prevention Module 6 Noise: Hazards and Prevention Module 7 Managing Welding Hazards: Workplace Hazards and Personal Protection Equipment Module 8 Managing Welding Hazards: Environmental Hazards, Confined Spaces, and Ventilation Safety Module 9 Process Specific Welding Safety: Oxyfuel Welding and Cutting Module 10 Process Specific Welding Safety: Arc Welding and Cutting Module 11 Process Specific Welding Safety: Resistance Welding, Electron Beam Welding, Brazing, and Soldering
D17.1 Code Clinic Select a Module Module 1 Introduction to the D17.1 Code Clinic Module 2 Understanding the D17.1 Code Applications Exam Module 3 Understanding the D17.1 Code: An Overview Module 4 Clause 1: Scope and General Requirements Module 5 Clause 2: Normative References Module 6 Clause 3: Terms and Definitions Module 7 Clause 4: Design of Welded Connections Module 8 Clause 5: Welding Performance and Procedure Qualification Module 9 Clause 6: Fabrication Module 10 Clause 7: Inspection Module 11 Clause 8: Repair of Existing Structures Module 12 Clause 9: Nonflight Hardware Module 13 Attacking the Question Module 14 Using Navigation Tools Module 15 Text, Table, and Figure Module 16 Tabbing and Highlighting Module 17 Test Taking Tips
D1.1 Online Code Clinic Select Module Module 1 Introduction Module 2 Clause 1 – General Requirements Module 3 Clause 2 – Design of Welded Connections Module 4 Clause 3 – Prequalification of WPSs Module 5 Clause 4 – Qualification Module 6 Clause 5 – Fabrication Module 7 Clause 6 – Inspection Module 8 Clause 7 – Stud Welding Module 9 Clause 8 – Strengthening and Repair of Existing Structures Module 10 Clause 9 – Tubular Structures
API 1104 Online Code Clinic Select Module Module 1 Introduction Module 2 How to Use API 1104 Module 3 Sections 1-4 Module 4 Section 5 Qualification of Welding Procedures with Filler Metal Additions Module 5 Section 6 Qualification of Welders Module 6 Section 7 Design and Preparation of a Joint for Production Welding Module 7 Section 8 and Section 9 Module 8 Section 10 and Section 11 Module 9 Section 12 and Section 13 Module 10 Annexes A-C
Understanding Welding Symbols Select Module Module 1 Fundamentals of Object Representation Module 2 Lines and Weld Joints Module 3 Weld Symbols: Groove, Fillet, Plug and Slot Welds Module 4 Weld Symbols: Spot and Projection, Stud, Seam, Back and Backing, Surfacing, and Edge Welds Module 5 Reading Welding Symbols: Basic Parts of a Welding Symbol, Weld Location, and Symbol Orientation Module 6 Reading Welding Symbols: Arrow, Reference Lines, and Supplementary Data Module 7 Reading Welding Symbols: Extent of Welding Module 8 Reading Welding Symbols: Tail, Contour Symbols, and Melt-Through Symbol Module 9 Groove Welds: Groove, Groove Welds, and Arrows Module 10 Groove Welds: Depth of Groove and Size Module 11 Groove Welds: Special Case Dimensions and Root Opening Module 12 Groove Welds: Groove Angle, Groove Radius, and Length Module 13 Groove Welds: Intermittent Welds and Weld Contours Module 14 Groove Welds: Back and Backing Welds Module 15 Groove Welds: Backing, Spacers, and Consumable Inserts Module 16 Groove Welds: Backgouging, Seal Welds, and Skewed Joints Module 17 Fillet Welds: Anatomy of a Fillet Weld, Size, Dimension Lines, and Notes in the Tail Module 18 Fillet Welds: Double Fillet Welds, Notes on a Print, Length, Hatching Lines, and Changes in Direction of Welding Module 19 Fillet Welds: Length and Intermittent Fillet Welds Module 20 Fillet Welds: Contours, Combined Weld Symbols, and Skewed Joints Module 21 Plug and Slot Welds: Plug Weld Size, Slot Weld Width and Length Module 22 Plug and Slot Welds: Angle of Countersink, Depth of Filling, and Number of Welds Module 23 Plug and Slot Welds: Pitch, Centerlines, and Joints with Three or More Members Module 24 Spot and Projection Welds: Size and Strength, Number of Welds, and Pitch Module 25 Spot and Projection Welds: Weld Process Reference, Grouped Spot Welds, and Multiple Member Spot Welds Module 26 Stud Welds Module 27 Seam Welds: Size, Strength, Welding Process Reference, and Length Module 28 Seam Welds: Intermittent Seam Welds, Number of Welds, Contours, and Multiple Member Seam Welds Module 29 Surfacing Welds Module 30 Edge Welds: Size, Length, Double Edge Welds, and Changes in Direction of Welding Module 31 Edge Welds: Chain Intermittent Edge Welds and Staggered Intermittent Edge Welds Module 32 Edge Welds: Extent, Location, Joints with Three of More Members, and Combined Weld Symbols Module 33 Brazing Symbols Module 34 Nondestructive Examination Symbols: Letter Designations, Side Significance, Multiple Tests, Combined Symbols, and Supplementary Symbols Module 35 Nondestructive Examination Symbols: Specifying Location and Extent of Examination Testing Symbols
Welding Fundamentals I Select Module Module 1 What is Welding? Module 2 Welding Processes and Weld Types Module 3 Welding Hazards and Environmental Protection Module 4 Managing Hazards and Accident Prevention Module 5 Oxyfuel Welding: Basics of Combustion, Fuel Types, and Flame Characteristics Module 6 Oxyfuel Welding: Advantages, Disadvantages, and Equipment Module 7 The Science of Arc Welding: Basics of Electricity Module 8 The Science of Arc Welding: Electrical Polarity and Arc Welding Equipment Module 9 Shielded Metal Arc Welding: Process Characteristics and Electrodes Module 10 Shielded Metal Arc Welding: Operations, Equipment, and Process Variables Module 11 Gas Tungsten Arc Welding: Principles, Operations, and Equipment Module 12 Gas Tungsten Arc Welding: Shielding Gases, and Process Variables Module 13 Gas Metal Arc Welding: Principles, Equipment, and Metal Transfer Modes Module 14 Gas Metal Arc Welding: Consumables, Shielding Gases, Equipment, and Process Variables Module 15 Flux Cored Arc Welding: Principles, Equipment, and Consumables Module 16 Flux Cored Arc Welding: Shielding Gases, Equipment, and Process Variables Module 17 Submerged Arc Welding: Principles, Equipment, and Materials Module 18 Submerged Arc Welding: Electrodes, Flux, Equipment, and Process Variables Module 19 Basics of Welding Metallurgy: Atomic Structures and Properties of Metals Module 20 Basics of Welding Metallurgy: States of Matter, Alloys, and Heat Affected Zones Module 21 Welding Discontinuities and Their Causes: Process, Metallurgical, and Base Metal Discontinuities Module 22 Welding Discontinuities and Their Causes: Structural Discontinuities Module 23 Oxyfuel Cutting Basics and Equipment Module 24 Oxyfuel Cutting Flame Types, Gas Types, and Cutting Variables Module 25 Oxyfuel Cutting Quality Limitations and Safety Module 26 Carbon Arc Cutting Basics and Equipment Module 27 Carbon Arc Cutting Operating Procedures & Safety Module 28 Plasma Arc Cutting Basics and Equipment Module 29 Plasma Arc Cutting Variables, Metallurgical Effects, Secondary Functions, and Safety
Welding Fundamentals II Select Module Module 1 Resistance Welding I: History & Science Module 2 Resistance Welding II: Equipment Module 3 Resistance Welding III: Consumables & Materials Module 4 Resistance Welding IV: Variables Module 5 Resistance Welding V: Safety Module 6 Resistance Welding VI: Spot & Projection Welding Module 7 Resistance Welding VII: Seam Welding & Advantages-Disadvantages Module 8 Plasma Arc Welding I: History, Science & Equipment Module 9 Plasma Arc Welding II: Variables & Advantages-Disadvantages Module 10 Electron Beam Welding I: History & Science I Module 11 Electron Beam Welding II: Science II Module 12 Electron Beam Welding III: Equipment I Module 13 Electron Beam Welding IV: Equipment II Module 14 Electron Beam Welding V: Variables & Safety Module 15 Electron Beam Welding VI: Advantages & Disadvantages Module 16 Laser Beam Processes I: History & Science Module 17 Laser Beam Processes II: Equipment, Consumables & Materials Module 18 Laser Beam Processes III: Cutting & Drilling Module 19 Laser Beam Processes IV: Variables Module 20 Laser Beam Processes V: Safety Module 21 Laser Beam Processes VI: Advantages & Disadvantages
Welding Fundamentals III Select a Module Module 1 Brazing: Introduction Module 2 Brazing: Equipment Module 3 Brazing: Process Variation Module 4 Brazing: Materials 1 Module 5 Brazing: Materials 2 Module 6 Brazing: Materials 3 Module 7 Brazing: Variables Module 8 Brazing: Safety Module 9 Brazing: Advantages and Disadvantages Module 10 Soldering: Introduction Module 11 Soldering: Equipment Module 12 Soldering: Process Variation Module 13 Soldering: Materials 1 Module 14 Soldering: Materials 2 Module 15 Soldering: Variables Module 16 Soldering: Safety Module 17 Soldering: Advantages and Disadvantages
WPS/PQR Explained Select a Module Module 1 Introduction to WPSs & PQRs Module 2 How to Read a WPS, Pt. I Module 3 How to Read a WPS, Pt. II Module 4 Procedure Specifications for Oxyfuel Welding, Resistance Welding, and Brazing Module 5 PQRs and Qualification Tests
_________________________________
*= Required
CAPTCHA
